Question when torquing stock rocker arm bolts?
Reinstalling my stock cam, pushrods, and new LS7 lifters. When torquing the rocker arm bolts to 22 ft/lbs should I do them while the piston is top dead center, or use the LS1howto method and torque them all down to 22 ft/lbs, rotate the crankshaft 180 degrees and recheck the torque on the bolts? Thanks!
