went to the track and now this
Old Jul 5, 2010 | 10:25 PM
nysbadmk8's Avatar
******* english would help, Now past that.. It sounds like you have multiple issues..
Have no idea what your mechanical skill level is.. But i would check your oil pressure with a mechanical gauge, because I believe you mentioned your oil pressure was around 20psi?
If that is true, you have an issue that isnt electrically related.
Old Jul 5, 2010 | 10:27 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by nysbadmk8
******* english would help.
Everyone else can understand it just fine. Thanks for your 2 cents. I am sure it will help him figure the problem out.
Old Jul 5, 2010 | 10:37 PM
Lanaue's Avatar
Did you check all your grounds?
Old Jul 5, 2010 | 10:39 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I know it would be a hassle to get it back to xxx, but if they screwed something up then they should fix it. Granted, most shops in their right mind are not going to put a warranty on anything that has knowingly been down the drag strip. Atleast call them up and tell them what is going on.
Old Jul 5, 2010 | 10:47 PM
slolt1's Avatar
well this is not what you gonna want to hear but the cherping is more than likely a rod bearing mine was doing the verry same thing
86zcamaro's Avatar
There might be codes that tell you something with a scan tool?
The only time I have lost oil pressure is when my car started overheating from the thermostat. It would spike and jump around a lot.
Wish I could help, call the shop and talk to them about it I guess.
Old Jul 5, 2010 | 11:07 PM
nysbadmk8's Avatar
No not really... And I added my two cents in helping the OP, not just pointing out the Sp errors.
But thanks for your informative Post.. I am sure it helped the OP too.
Old Jul 5, 2010 | 11:09 PM
nysbadmk8's Avatar
Well If i read correctly the OP said he tried or did drive his car home on 20 psi of oil pressure..
I would be inclined to believe its internal also.
Old Jul 6, 2010 | 12:48 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
After you saw my post you went back and edited it. I quoted the whole thing originally. He doesnt need people telling him to learn English.
Old Jul 6, 2010 | 12:52 AM
SILVER 2288 SS's Avatar
From: boaring place where theres more cows than people
id check the plugs as well my car acted this way and did the same thing when i fouled 4 plugs out
Old Jul 6, 2010 | 01:21 AM
Soul TKR's Avatar
I'm thinking rod bearing as well...
Old Jul 6, 2010 | 08:42 AM
  #32
nysbadmk8's Avatar
I have no idea what your talking about... Its dropped, Move on.
Old Jul 6, 2010 | 08:58 AM
  #33
MPFD's Avatar
11 Second Truck Club
Why would an internal component cause his dash to go stop operation? He said it still drove fine during the first pass. I think also that there is a bad ground some where. You said you had a pinched ground wire did you clip it and repair it or just free it? I had a ground wire loose when first started my 6 liter for the first time and my dash fluttered and stopped working, and the truck ran like **** till I got it found and tight. Check and make sure all grounds are tight and in good working order. I think the sound is too sporadic to be a rod. It also doesn't seem to coincide with RPM like a rod would all the bad rod bearings I've ever heard get alot louder and deeper sounding then that with rpm increase. JMO...
Old Jul 6, 2010 | 09:58 AM
  #34
DLindlZ28's Avatar
I Redone the wire. its no longer a player. And no my mecanical knowledge is not the greatest ,but thats why im on ls1 tech trying to learn something new. Im going to take it around the block with a camera . the car has not moved since the wrecker dropped it off
Old Jul 6, 2010 | 10:46 AM
  #35
MPFD's Avatar
Does the dash work now, but the motor just runs like ****?
Old Jul 6, 2010 | 10:59 AM
  #36
nysbadmk8's Avatar
Where Is the Oil pressure at?
Old Jul 6, 2010 | 11:07 AM
  #37
MPFD's Avatar
But is that being read off the dash or not? If the dash is on the glitch it might not be reading correctly...
Old Jul 6, 2010 | 05:01 PM
  #38
DLindlZ28's Avatar
i didnt get a chace to drive it today but the oil pressure at idel is normal sitting at 40. the chirp/squeal noise is gone my bad it was a pully. I have a buddy coming down from VA this weekend to help me out. he also thinks is a bad ground so we are going to track it down. thanks for everones help i really needed this to calm my nerves and to keep from going ape **** over my car!
Old Jul 6, 2010 | 10:02 PM
  #39
nysbadmk8's Avatar
Chase your grounding issue. Thats all it sounds like right now.
Old Jul 6, 2010 | 10:11 PM
  #40
LCW's Avatar
LCW
Kind of sounds like this diesel sound could possibly be a vacuum leak from somewhere around your intake. Maybe check the back where the map sensor and vacuum lines come from.
Good luck hope you get it fixed.
