oil in the intake bad
Old Jul 6, 2010 | 08:16 PM
slolt1's Avatar
Default oil in the intake bad
i have noticed the car burning oil.i pulld the t/b off today to send out for porting and noticed fresh oil on the blade its built up in the intake around the pvc.
is there a way to reroute the pvc out of the intake or delete it all together ?
the car is a 99 and thanks for the help
Old Jul 6, 2010 | 08:22 PM
LS12Fast4U's Avatar
I know there is a way to eliminate the PCV system all together by adding a breather adn capping of the lines. Also you can get a catch can to run in line with the PCV system.
Try a search on here and you will come up with how a lot of people have done it.
Old Jul 6, 2010 | 09:59 PM
peterlawl84's Avatar
you can also convert it to the LS6 PCV system, that alone has cut down on my oil consumption.
If you still have issues, then you can add a catch can as well.
Old Jul 6, 2010 | 10:36 PM
garygnu's Avatar
install a catch can or get a water separator for air compressors from home depot and use it as a catch can,cost $20.
