7100 redline w/ stock LS6?
stronger pushrods (Chromoly) - to handle the repeated abuse
high tensile strength rod bolts - to handle the increased forces during piston directional speed changes
high rate springs (preferrably single) - to decrease valve float at higher RPMs
Someone mentioned PAC 1518 springs. Can anyone else recommend other good low lift high RPM valve springs?
My goal is to set the limiter to maybe 7000, and shift at around 6800, but I'd like piece of mind in case i'm ever forced to bounce off the limiter for more than a second.
