Cam decision help!
Old Jul 12, 2010 | 01:14 PM
*02WS6TURK*'s Avatar
Default Cam decision help!
I need some help or suggestions on which cam I should decide on. MODS in SIG. This will be a cam only swap. Might potentially do heads in the future but more then likely not. Looking for something that's going to have good power/torque in the low/mid range. I am wanting something that will net me close to 35-45 more RWH to get me close to that 400RWH mark. So far I'm looking into these...
Texas Speed 228R and the 224 or
222/223 .578/.578 or .600/.600
225/229 .578/.578 or .600/.600
Whichever I go with will be on a 112 LSA. Any thoughts guy's? Thanks!
Old Jul 12, 2010 | 01:47 PM
aTeam's Avatar
I'd go with the 228R if I were you
Old Jul 12, 2010 | 01:51 PM
Bo's 98 TA's Avatar
Deff. 228r no smaller.
Old Jul 12, 2010 | 03:23 PM
On the 228R, Should I stick with the .588/.588 lift or should I bump it up to a .600/.600? I will be running the Patriot Gold Extreme valve springs.
Thanks
Old Jul 12, 2010 | 03:28 PM
smok'nZ's Avatar
MASS seller approved
get a custom spec'd cam, and if your just hunting for 400 rwhp get a ms3/ms4/trex/vindicator/street sweeper/polluter etc.... they all have been known to put down well over 400 with the right mods/tune
Old Jul 12, 2010 | 04:39 PM
I'm more concerned with getting something with good torque and HP under the curve. Don't want anything that big like the MS3 OR 4 etc etc. I would rather have it in the 380-390 range and be able to utilize the power w/o having to spin it to the moon.
Old Jul 12, 2010 | 05:46 PM
TXZ28LS1's Avatar
i would honestly step up to just a tad bit more cam..go with atleast a torquer V2..its a 232/234.
Old Jul 12, 2010 | 05:58 PM
JPH's Avatar
JPH
That 228 cam is a nice grind, and it's hard to beat the performance of the 224 cam also. It works so well in many applications.
Old Jul 12, 2010 | 06:23 PM
desertLS1's Avatar
Get a custom spec, something in the 228/230 range. I'm running a VRX4 from vengeance racing. Cam is awesome and it's also my DD. I have stock LS6 heads and a ported FAST 92 and made dam well over 400rwhp, thru a stalled auto.
Old Jul 13, 2010 | 12:00 AM
fatboyq's Avatar
225/229 keep it under 600 lift
I like the split pattern, smaller cams give more power soon than big cams, u need tq to get that f body going....
I also like the 228/232 cam g5x1 etc
streetsweeper fti 220/224
Old Jul 13, 2010 | 12:31 AM
stryder's Avatar
i say do a 228/232 114+4 on comp XE-R lobes something like .588 intake .595 exhaust. thats pretty much a close to perfect all around cam.
Old Jul 13, 2010 | 06:14 AM
So fill me in on some terminology because I'm still learning...what exactly does it mean when people say "114+4 or 112+2" etc etc..I'm a little confused about the "+" part.
Old Jul 13, 2010 | 10:51 AM
JPH's Avatar
JPH
+?=advance ground into the camshaft!
114+4= 114LSA and 110ICL
112+2= 112LSA and 110ICL
Old Jul 13, 2010 | 12:11 PM
Ahhhh...thanks dude. And thanks to everyone with their suggestions
Old Jul 13, 2010 | 01:41 PM
99Bluz28's Avatar
Crane Cams Z Series Camshaft 228/232 112LSA would be a good off the shelf grind.
http://www.ws6project.com/user_stor/...=5c13650a9fb64
Old Jul 13, 2010 | 05:20 PM
garygnu's Avatar
the more advance a cam has the sooner it peaks in power,a little more torque.you can get a custom cam ground for $25 more ,I suggest a EPS cam.more power less duration.
Old Jul 13, 2010 | 09:00 PM
EPS? Who or what is this?
Old Jul 14, 2010 | 09:58 AM
Ethan[ws6]'s Avatar
You prob wont hit 400 horse with that small of a cam.
Old Jul 14, 2010 | 11:11 AM
Which one? There have been several different ones mentioned in here..
Old Jul 14, 2010 | 12:16 PM
printmanjackson's Avatar
http://www.engpwrsys.com/
Geoff Skinner is the man
