Disaster at the drag strip... possible bent pushrods.....
Old Feb 23, 2003 | 07:21 PM
BTLFEDLS1's Avatar
Default Disaster at the drag strip... possible bent pushrods.....
Last run today shifting from 3rd the 4th i believe i hit second. the low trac. light came on and the car jerked and sounded like it broke in half. rolling through 3/4 track the car died and would not start right away when i stopped and tried to start it. I got it strarted and drove it home. I barly idles and when you reach the friction point the shifter and tranny shake like S$#&. any help would be appreciated. mario
Old Feb 23, 2003 | 08:33 PM
DaddySS's Avatar
Default Re: Disaster at the drag strip... possible bent pushrods.....
Sounds like bent push rods, so if that's all it is consider yourself lucky. Check it out immediately.
Old Feb 23, 2003 | 08:51 PM
jason hamilton's Avatar
if push rods bent you better do a cyl leak down test. more than likely valves will be bent too
Old Feb 24, 2003 | 02:34 AM
BTLFEDLS1's Avatar
when the car is running it barly idles and there is a fast ticking noise. I just hope it is nothing more than pushrods and valves. the fu#*&# up thing is i have to drive it to a friends house to have him look at it. how expensive will it be for parts pushrods and valves ect. thanks mario
Old Feb 24, 2003 | 02:46 AM
35th SS's Avatar
it could also be a spun rod bearing.check it out right away.good luck.
Old May 21, 2009 | 02:47 PM
EltonBay's Avatar
Default Please, help me, brothers!!!
Yes.
XRumer 5.0 Palladium it the best soft for promo anyway.
I was promoted more than 100 my web-satellites up to Google's TOP-10 (keywords - adult and pharma)
Old May 21, 2009 | 05:44 PM
cellulis44's Avatar
are you a spammer.....
Old May 21, 2009 | 06:29 PM
superchargedgp's Avatar
nooooooooo... what gave it away?
