Got a cam, need to make a choice on heads.
car is a 2002 Z28 with full bolt-ons, built and stalled auto with 3.73's.
the cam is a custom grind thunder racing 111 LSA .614/.586 lift. duration is in the 232/229 range. I am getting the exact duration sent to me from the seller (a friend I trust). it made 384 whp cam only with stock heads through a stalled built auto on his car. I am planning on calling Texas speed to see if it would be worth sending the heads to them to be ported after I get the exact Cam specs.
anyway. I found a good deal on some 5.3 heads ($200 complete). I have read u need to port the exhaust valves and port for larger valves. I have searched, but I havent found much info other than classified ads. I want AT LEAST 400 whp with this cam and I think its more than possible.
so should I just port the stock LS1 heads or port the 5.3's?
You can get some cheap 243's or 799's if you scan the classified ads and craigslist. $300ish. This would be a better investment, and if the funds allow, have a decent VJ/bowl blend done.
^^This seems to be the best bang-for-the-buck combination.
We get the 5.3L castings inexpensively enough that unless you get yours for free or close to it ($100 or less), it doesn't make sense to port your 5.3's.
To clarify: You can save money on the LS6's by sending them in to be ported since that casting is a bit more expensive....but with the 5.3's that is typically not the case.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I am leaning towards just porting the stock heads. even if I dont reach the goal of making over 400whp it would be close. I found a local shop that does porting and I have talked to a couple people with good first hand experiences. $400 for a full port and valve job is what they usually charge.
Did they doctor the cam for you?
