looking for good rockers for tfs 235 heads
i just got my trick flow 235's in and im looking to get some good rockers. just looking for some rec, i.e, t and d, jesel, etc. based on price and value
I just went the same process with a set of TFS 215s. I ended up with the Jesel non-adjustable shaft mounted rockers. They required no machine work to the heads, no shimming to get the correct geometry, they worked wtihout valve cover spacers, and seem to be very solid. They also allowed the use of Manton Grade 5 pushrods. They were used inconjunction with Morel lifters with 0.050 preload and the valve train is quieter than stock.
