Does a cam make a car louder??
Old Jan 19, 2004 | 08:02 PM
99-LS1-SS's Avatar
STF Veteran
Default Does a cam make a car louder??
Just like the title. I just put a set of LT's on and an ORY and DAMN my car is loud. It sounds like a milk truck with no muffler until I floor it and then it sounds good. I really wish it was a little quieter just cruising around. I have a TSP 224R cam that I am getting installed within the next 2-3 weeks. I was just wondering if it is going to be even louder?
98_1LE's Avatar
My little TR220 cam made my car noticeably louder, even at idle.
Put cats on it and you will be happy
Old Jan 19, 2004 | 08:04 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
My B1 seemed to make the car louder.
I am anti-cat. Just run a full plate in your Borla setup, as posted in the other thread. You can make one if you can't buy it....
99-LS1-SS's Avatar
STF Veteran
I guess that is what I am going to have to do.
Old Jan 19, 2004 | 08:08 PM
Mike98WS6's Avatar
My car is louder and has a lope to it at idle.
Old Jan 19, 2004 | 08:16 PM
99-LS1-SS's Avatar
STF Veteran
Did any of you guys have LT's and an ORY before you had cam's? If so do you know what I mean when I am explaining how the car sounds just driving "normal"? My car just sounds like my muffler fell off when I am just ruising around. But when I floor it it sounds very good. Will a cam help with the "sloppy" sound and normal revs?
Old Jan 19, 2004 | 08:18 PM
foff667's Avatar
LS1TECH Sponsor
i have the same exact setup as you i understand what it sounds like with a borla and no plates its loud get used to it or take 5 minutes and $5 and make and install a plate for yourself...I like the sound of mine and cant wait to get my cam can heads installed
Old Jan 19, 2004 | 08:34 PM
RPM WS6's Avatar
The sloppy sound will go away if you run it through the muffler. It's an easy fix, really Plates are easy to make if you don't have them.
Old Jan 19, 2004 | 10:21 PM
Colonel's Avatar
Mine sounds the same now as it did with the stock cam...but then I have the stock muffler in place too.
Old Jan 19, 2004 | 10:22 PM
Chicago Crew UnderBoss's Avatar
Its has also been my experience that in addition to the avove comments the valve train noise also increases significantly with a aftermarket performance LS1 cam!
Old Jan 19, 2004 | 10:42 PM
Colonel's Avatar
Very true. The more aggressive the lobes and the bigger the cam, the more valvetrain noise you'll have. Bothers some people and not others. I really only notice mine when I'm beside a wall with the window rolled down (like in a drive thru.)
Old Jan 19, 2004 | 10:46 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Went from C1 to TSP231.237 and found that the cam alone made a deeper tone.
99, you'll find that the chop from the 224 cam will enhance the milktruck sound for the better.
Old Jan 19, 2004 | 10:49 PM
Slowhawk's Avatar
LS1Tech Sponsor
I found the bigger the cam the louder the car is and the interior noise went up.I run the SLP dual dual in the non-race season and the muffler sounds like it's ready to blow open at WOT.
Old Jan 20, 2004 | 09:56 AM
SSCamaro99_3's Avatar
Yes, mine got deeper and louder.
