Questions for guys with C5R heads...
2. Are the chambers set up for 4.125" bores? If not, what bore size?
3. Is anyone using them on a regular LS1 block?
4. I believe Ronnie Duke's car is running them. Is there enough material there to open up the chambers to like 50cc?
Thanks in advance for any feedback.
2. The chamber is around 44cc with the GMPP cnc set, fits best on 4.125 bore.
3. I have used them on a 4 inch bore ls block with a 2.125- 1.6 valves.
4. My guess is you could get them to 50cc, but I have never done that.
Kurt
Kurt
Jesel prices are starting to get better and they have a great track record for durability, this was my main concern. The C5R heads are a great hi-power head but so specialized the cost is high. If you decide to use them you will love the power potential!
Kurt
i wonder how they would do on a 4.060 iron block. like steve mentioned, you can order them through any dealer, but they're gonna be steep. any dealer employee can get them at cost plus ten percent though, so thats a lil closer to the ballpark.
I'm sure the head would be better yet on the 4.060 bore.
You might want to check Scoggins Dickey for price on the CNC set.
Kurt
2. Heads are designed for "Large bore"block..
3. With Darton sleeves MID..
4. Have had them CNC'd to 62cc down here in OZ.
Cheers
AL.
