how does this setup sound?
TSP 383 rotating assembly(forged crank,rods,pistons)
Ms4 cam
PRC ls6 heads
patriot dual golds
harpland sharp rockers(or something similar)
7.4 hardened pushrods
42lb injectors
fast 90/90
ls7 lifters-or should i do better ones?
hows this sound? i will probably end up spraying a 150-200hp plate system but only at the track.
i want 480+whp n.a. btw its a M6 car.
thanks-curt
Anyways, it sounds like a good setup! What clutch & master cylinder are you going to use? just dont forget to budget in new bearings & gaskets
