Oil pump replacement question
Old Jul 21, 2010 | 07:48 AM
Klimaxx's Avatar
Default Oil pump replacement question
I will be doing a cam swap (blower cam to go with a TVS 1900..any cam recomendations?) and replacing the oil pump atthe same time (ported ls6 is my plan). do i need to drop the oil pan to swap pumps? or will having the front cover off be enough? Thanks for your help! I did a search bun couldn't find this answer. Hopfully i dont need to pull the engine..
Old Jul 21, 2010 | 07:53 AM
chon79's Avatar
Finishing up my cam install now. You will need to drop all oil pan bolts (12 total I think) to drop the pan about 1''. A 10mm gear wrench will be VERY handy for this.
Old Jul 21, 2010 | 08:05 AM
Klimaxx's Avatar
thanks! just what i wanted to know..
