how to break in new engine?
You're probably gonna get 100 different opinions on this, but I agree with progressive loading, then drive it like you stole it. Others say to do hard accel/decel loading to seat the rings right away. It may be better, but it's kind of like ***-raping your girl on the first date... just doesn't seem right.
Make sure the oil is warm and the tune is safe and then go ahead and *** rape it to seat the rings. I haven't broken in a new motor in over ten years but that worked well for me ten years ago. That motor is still alive though not in my driveway any more...http://www.mototuneusa.com/break_in_secrets.htm
i went around a disused airfield so i could work it up and down the gears quite hard, without sticking too long at one rpm point. a bit of steady acceleration and the odd decent hard pull, and letting it off throttle with some engine braking.
after 20mins switch off, let it cool down fully to heat cycle it all, then change the oil and filter, again for non synthetic mineral oil.
after that initial break in the engine got worked to full rpm on its very next outing, and was given quite a hard run, probably less than 100miles on the clock at this point, 6000rpm and full throttle acceleration for about 40mins.
the engine uses no oil and sounds sweet as a nut, and has since done about 400 track miles of very hard use. still on mineral oil (changed again). was advised to avoid synth for first 1k miles.
Was trying to figure a way to reply to chris-m as he had made the remark about what his engine guy had said.
