more afr delays
Reminds me off all the AFR vs TW head threads on the mustang boards.
& what it really comes down to (head wise) is velocity (as some have mentioned).
I say it all the time to the Ford guys.... Velocity is key in making good power.
But it really comes down to the entire combination. You can't have 1 good part & expect it to make up for the rest of the combination.
I've seen combinations with heads that flow 50+cfm less then another combinations, yet run faster at the track. I recently built a combination JUST to prove this point.
'Velocity is Power'
(i grasp some of what was said) without trying to start another 7 page thread
any ruff ideas on cams for these heads??? i am a "stealth" kind of guy.
Already getting things in motion for the AFR combos as well as the trick "drop-in" valve spring/ti retainer/lock deal. I've got to get you a pic of the cool valve cover spacers. They allow a lot of clearance for the Jesel shaft rockers...
You know how much I hate "shelf" cams but I've been getting a lot of Emails for them soooooo..... It looks like I may have to design up a few "close" ones for those who are a bit impatient for a true custom...
Let ya know...
Spanky: CNC 205 with production valve job. More with a bit of tweaking and refining....
Ed
AFR 205 (4.125" bore fixture and a 1.875" flow tube)
Lift - Intake/Exhaust
.20 - 144/116
.30 - 208/170
.40 - 255/206
.50 - 287/221
.55 - 296/227
.60 - 302/232
.65 - 304/236
They also list flow #'s for a Stock LS1, Stock LS6, and GMPP LS6.
They of course emphasize the fact that this head's advantage comes from the increased velocity with less port volume while maintaining a high flow rate.
It all sounds like a recipe for more power to me, but I'm waiting to see the dyno/track results. Personally..... I can't wait to see the results, especially since I'll be buying heads for my car about the time we'll see some actual dyn0/track #'s for these (I hope).
So does anyone know of someone with these heads on their car yet?
