Car running like CHIT
Old Feb 24, 2003 | 08:00 AM
KraZy's Avatar
Default Car running like CHIT
'00 TA with lid/filter.
Car is running strong/well.....but at idle is goes lower than 500 rpms and revs back up. Soo it seems like my basically stock TA has a lope. Also the oil pressure cage surges at the same time that it revs back up.
Is there something I check or do? I changed half the spark plugs this weekend....passenger is a bitch.
Thanks guys!
Old Feb 25, 2003 | 06:01 AM
KraZy's Avatar
Default Re: Car running like CHIT
Please? Just need a little hint in the right direction.
Old Feb 25, 2003 | 01:00 PM
Cal's Avatar
Cal
Check your IAC solenoid and associated connetor and wiring. The problem is probably related to the PCM. I can't do anything about your passenger! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ February 25, 2003, 01:03 PM: Message edited by: Cal ]</small>
Old Feb 25, 2003 | 01:04 PM
ALPINE's Avatar
Passabger side isn't so bad if ya take the things in the way off, and you put them back on heh.
Old Feb 25, 2003 | 06:42 PM
SScamaro's Avatar
Is the MAF ok after you put your lid on? Check and double check. Did you do plugs because of the problem, or did you have a problem after the plugs. Sounds like the surge could also be computer related. Battery disconnected recently? If so, drive it a bit. Mine surges, but I know y. LS1edit is on the way. Does you car run good when you drive it? Is it an auto or a stick?
Old Feb 25, 2003 | 09:06 PM
KraZy's Avatar
Hehe, the passenger is still a bitch....and the spark plugs as well.
I noticed the car idling rough 20k miles ago, had the injectors cleaned....no help. I recently had a TC installed, and they reset my PCM because it was throwing a SES Light....was told it was o2 sensor. Light has not come back on since the reset. Could the o2 sensor cause the rough idle?
The car runs fine and strong. 13.4 with lid....my dyno was rough ('00).
Thanks for the input guys!!
BTW will be in Orlando this weekend! WOOOhoooo
Old Feb 26, 2003 | 07:55 AM
KraZy's Avatar
<img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" />
I think you are right Hat'r
Runs fine till warmed.
And I thought the garage ripped me a new one saying it was a sensor.
Thanks for the help guys
