4 inch strokers reliable?
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Always be aware that Wearable parts will always need to be monitored and checked. I do not care if its a Patriot Dual Gold, or a 918 Comp Spring. Aside from a occasional Mis-build of a motor, valve train failure are proabably the next biggest thing that can happen at any time and in most situations a dropped/bent valve is more catastrophic.
With strokers, most also run aggressive cams and some people never think about matience.
I learned the hard way 3-4 years ago on a 383 LT1 with Comp 987's and luckily it caught the valve, bent it up, the head was fixable, and the piston Magnafluxed fine but had it been something else, I could have been looking at a total re-do and 7k out the window.
