Is this a L33
Old Aug 4, 2010 | 04:36 AM
hinds90's Avatar
Default Is this a L33
Just picked this engine up off the net. Can anyone tell just buy looking at it if its a L33 just want tp be sure. The vin matched up with a 05 4x4 silverado.
On a side note would a ls6 inake manifold and cam be a good upgrade on this engine. Motor is going in a bmw.
Old Aug 4, 2010 | 06:26 AM
SweetS10V8's Avatar
The L33 is the only aluminum block 5.3L that exsited, that I know of, in 2005. IF you have the vin number look for vin "B"
Old Aug 4, 2010 | 06:46 AM
hinds90's Avatar
Yeah the vin they gave me matches up with a 05 4x4 chevy silverado. Just trying to make sure.
Old Aug 4, 2010 | 09:06 AM
The_Rizzle's Avatar
heads will be 243/799's. If you're still not sure, pull off the water pump, there should be a 5.3 casting in the bottom of the driver side coolant hole.
Old Aug 4, 2010 | 09:07 AM
Rhino's Avatar
I can't really tell 100% from the pics, but I would tend to think that was an iron block. if that's the case, it's an LM7.
Just as previously stated, an easy way to tell would be to look at the casting numbers on the heads.
Old Aug 4, 2010 | 10:35 AM
hinds90's Avatar
I hope its a L33. The 8th letter in the vin# is B, it came out of a 05 extended cab 4x4. I just talked to the place I bought the engine from and there going to try an get better pics and pics of head castings.
Old Aug 4, 2010 | 12:06 PM
twitchtwice's Avatar
there is a number on the block. can you post it up?
Old Aug 4, 2010 | 01:02 PM
hinds90's Avatar
1GCEK19B65E328463 this is the vin to the truck. It was in the forsale ad.
Old Aug 4, 2010 | 09:16 PM
SweetS10V8's Avatar
B = l33
Old Aug 4, 2010 | 10:17 PM
Irish350's Avatar
yeah its dirty so it looks iron, but if you look at the boltholes (that arent a cover) you can see its aluminum, so if its not iron and it came from a silverado youre good to go main; as stated, those are the only aluminum truck blocks
Old Aug 4, 2010 | 10:19 PM
Coban's Avatar
2005 4X4 were one of the few (only?) trucks that got this engine. Looks like an aluminum block to me. Iron ones were painted black.
Old Aug 5, 2010 | 06:11 AM
SweetS10V8's Avatar
You can see that it is an aluminum block. Its an L33...
