Engine Modifications Questions?
Old Aug 4, 2010 | 02:58 PM
BlackedOut LS1's Avatar
Default Engine Modifications Questions?
Since I have to remove the heads on my 98 T/A to get to the lifters, should I take them to get machined? Basically the car has about 140k miles on it, the engine area isn't as quiet as it was when I purchased it at 42k miles, and I want some more horsepower. I have about $2500 to play with, and can do most of the labor. What do you guys suggest?
Old Aug 4, 2010 | 03:36 PM
Rhino's Avatar
In my opinion, if you're looking for horsepower, you're not likely to find it in those heads (assuming they're stock). For $2500 you could easily do a heads/cam swap if you're interested.
I have less than that into all new bearings, cleaned up set of used heads, cam, lifters, push rods, and a full gasket set in my rebuild.
