Need some timing help ASAP
Old Aug 7, 2010 | 12:43 PM
zspot98's Avatar
Default Need some timing help ASAP
I am in the middle of doing my cam swap and totally forgot to set the cam sprocket dot and crank sprocket dot before I took the cam out. I spun the crank until the dot was at 12 o'clock and then spun the cam until the dot was at 6 o'clock. After that I connected the timing chain and spun the motor over by hand 15 or 20 times and the dots line up every time, does this mean I am ok? Or is there a chance I am still out of sequence?
Any help would be greatly appreciated.
Old Aug 7, 2010 | 01:43 PM
09camaro383's Avatar
Dot to Dot and number 1 piston all the way up and you are good to go!!!
Old Aug 7, 2010 | 01:51 PM
SweetS10V8's Avatar
As long as its dot to dot your good to go, everything else will fall into line.
Old Aug 7, 2010 | 07:14 PM
printmanjackson's Avatar
you can also do both dots at the top
Old Aug 7, 2010 | 08:08 PM
vettenuts's Avatar
You're good and you don't need to line it up during disassembly. If they line up correctly and you have spun it a few times you are OK.
Old Aug 7, 2010 | 11:52 PM
zspot98's Avatar
Thanks for all the responses! I guess we'll find out if all is good when we start it up?
