Is this normal for a cammed car?
Old Aug 7, 2010 | 07:40 PM
arioch's Avatar
Default Is this normal for a cammed car?
So just got the car cammed and now it occasionally dies while im driving around, is this normal? is it so called "cam surge"? or something that needs to be addressed in a tune?
Old Aug 7, 2010 | 07:43 PM
jsteele90's Avatar
needs to be tuned
Old Aug 7, 2010 | 07:45 PM
jmill96Z's Avatar
Yes, when you change the cam, you need a tune.
Old Aug 7, 2010 | 07:54 PM
hcb1700's Avatar
Definitely need a tune if you changed the cam.
Old Aug 7, 2010 | 09:21 PM
arioch's Avatar
Let me correct myself:
Its already been tuned, think i need to take it back? its only died on me twice
Old Aug 7, 2010 | 09:24 PM
LaBLKv6Z's Avatar
Yeah, have them street tune it or bring it to another tuner. It dies while you're in gear?
Old Aug 7, 2010 | 09:32 PM
arioch's Avatar
in gear with the clutch in, itll stay alive if i notice the rpms drop and i give it some gas, its tried to die 3 times on me, in gear.
I think im gonna take it to another tuner since HPE keeps ******* **** up it seems
Old Aug 8, 2010 | 03:45 AM
01ssreda4's Avatar
Sounds like it may need a tad more idle rpms. I'm no tuner though but my car needed some bump in idle rpms bc it would die coming to a stop. Upped the idle by about 100 and it hasn't done it since.
 Michael S. Palmer
Old Aug 8, 2010 | 03:56 AM
same o'j's Avatar
need to check all your sensor after that tune
Old Aug 8, 2010 | 04:10 AM
TXZ28LS1's Avatar
my car died out, and bucked and everything after i got my cam installed. the tune definitely needs to be tweaked more.
Old Aug 8, 2010 | 07:38 AM
KRAZY K 2000 TA's Avatar
id say you have a poor tune,look at the cam in my sig i tuned it myself and it idled like a rock!!
Old Aug 9, 2010 | 06:35 AM
sayed_000's Avatar
same thing here my cam only car dies a lot on low speed and traffic lights .. specially with a/c on ..
time for new a tune + tuner ..
Old Aug 9, 2010 | 08:22 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Sounds like a minor tweak is required. IF you dont touch the WOT spark/fuel tables the average monkey with a laptop and a wideband can dial in their driveability, as most needs to log data and seat time and start messing with the settings.
IF you just want a tweak, contact the old tuner or find a new one.
Old Aug 9, 2010 | 02:00 PM
Midnight02's Avatar
More than likely the problem lies in your tune. It often times takes a little work to dial things in perfectly. I had a little surging too however took it back to the shop and haven't had a problem since.
Old Aug 9, 2010 | 02:25 PM
Internet Mechanic
Also to add a tune for Bolt ons per say is not the same tune for a cam. They tune maybe right for what it was tuned for but when you add a "Cranky" cam, you need to adj accordingly.
Old Aug 16, 2010 | 04:08 AM
arioch's Avatar
alright it was re-dyno tuned and now it doesnt die. it normally idles at 800rpms but randomly coming to a light it will drop all the way down to 200 and the lights will dim like its going to die, it will then rev itself back up and drop again to 200 before finally coming back up to its 800 idle...
I need to find a new tuner dont I?
Old Aug 16, 2010 | 06:50 AM
35thredz's Avatar
Yes,find someone who will take the time and have it street tuned.
Old Aug 16, 2010 | 06:00 PM
nazztyz06's Avatar
Yea get it street tuned.
Old Aug 16, 2010 | 06:13 PM
Rawr256's Avatar
Car is running too rich. Had the same issue with my wife's car after a cam and finally quit being lazy and got the O2 bunge welded in and hooked up the wideband. Coming to a stop the commanded AFR was where it was supposed to be but the actual AFR was down around 10.9. Basically it was just struggling to run past how rich the idle was. At WOT on the dyno AFR was right at about 12.7 also.
