are 2.08 valves to large for a stock bore ls1?
IM looking for a set of heads to use on my stock bottom end ls6 and was wondering if a 208 valve would be too large for the stock ls6 bore? I know its pushing it but would the 208 valves cause problems?
The following users liked this post:
Homer_Simpson (01-17-2022)
I am running afr 225's with the 2.08 valves with no issues. It's in a 383 3.905 bore. ms3 cam. plenty of clearance though low end torque may suffer I can't tell. 470 rwhp through an auto with 4200 stall.
LS1Tech Premium Sponsor
As stated, a 2.08" valve, while it will clear the bore, will be severely shrouded on a 3.898-3.908" bore.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Super Hulk Smash
2.02 is not the biggest you can fit.
Most aftermarket heads have larger valves than this... including the AFR 225 small bore.
Most ported heads use a 2.04" or 2.055" valve for the stock bore LS1. But you can make great power with the stock 2.00" valve as Ai generally takes this approach.
Stock valves are lighter than standard stainless aftermarket and that makes valve control a little easier. With a 2.08" valve, you have a heavy valve that requires more spring to control. And more spring puts more stress on guides, pushrods, and lifters.
Piston-to-valve clearance is the issue as well as shrouding as has been said before.
You can run it, but you better check clearance before you run it.
Moderator
Look at it this way, a 2.08" valve is roughly 53% of a 3.898" bore. A 2.165" valve is 54% of a 4" bore, and I don't see people having too many issues with L92 heads on a stock bore LQ9. If I remember correctly, some of the highest horsepower LS1's are using hollow stem LS3 valves turned down to 2.08".
Guys what my prediciment is....
347 standard bore built motor, ported 241.
Drag car only!
I am moving to a larger cubed motor late next year.
However i need to upgrade heads, so i got a deal on some All Pro heads, 6 bolt.
Just not sure what is the biggest valve that will fit in this 3.9 bore.
If they will fit?
but not as efficent?
I can live with until i get my new short block.
Drag car only!
If they will fit?
It actually has nothing to do with PTV clearance. When the valve is at max lift the piston is at the bottom of the piston chamber.
im running a stock short block with 2.08 intakes..... im not sure if it is the fastest set of heads out there but i have been running them for 30k miles or so and unless the cobra has a ken belle it will hold its own!
