how to prove if these heads were from Texas speed? pics..
before i buy them i want to know .. if these real texas-speed 243 stage 2.5
how to prove?
found the cast number and two porting numbers ...
help..
how to prove?
help..
LS1Tech Premium Sponsor
For the past year or year and a half we've been grind down that particular "243" casting and cutting "PRC" into that spot. So if they are PRC's, they are a good bit older. Up until about a month or two ago, we didn't put unique serial numbers on them. Now when you purchase, your invoice, the cylinder head, and our work order for the heads all have a unique serial number on them so we can track them better!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Anymore pictures? Of the runners,chambers? still would be hard to tell bur maybe they would recognize thier machine work? Like Matt said over a year ago thier heads leave with PRC compenents and STG 2.5 there where the 243 is.
