help with head and cam
Old Aug 12, 2010 | 09:48 PM
firehawk196's Avatar
Question help with head and cam
i took off my heads to clean the ports up and was hoping someone can tell me what order i tq. the bolts in and whats the ft.lbs also do i need a special tool to take off the pully so i can swap out my cam if so where can i get it at thanks
Old Aug 12, 2010 | 10:42 PM
Lambert695's Avatar
you can find it on a couple sites like ls1howto.com. it goes from the center out basically. then you can rent a pulley puller from autozone for free. thats what i did.
Old Aug 12, 2010 | 11:12 PM
thanks umm i have a pulley puller but it dont look like it will work ?? do ls1`s need a special one or ????
Old Aug 13, 2010 | 02:26 AM
racerfox's Avatar
ls1howto.com
Old Aug 13, 2010 | 04:50 AM
vettenuts's Avatar
Don't use LS1howto.com to remove or install the pulley. If you do, you will likely damage the threads of the crankshaft. You need to make a tool for installation.
Old Aug 13, 2010 | 01:17 PM
eallanboggs's Avatar
Harbor Freight sells a puller for serpentine pulleys. The jaws are serrated just like the shape of the "V" shaped notches on the pulley/belt. I had to modify mine to get it to fit the LS series crank pulley which is a large diameter. I used a longer shaft for the jaws to ride on and milled 2 keyways for the set screws in the puller jaws and drilled and tapped threads for the puller rod. This is also a special tool($40) for pushing the pulley back on.
Old Aug 14, 2010 | 12:41 AM
stryder's Avatar
for the pulley puller go to a kragen/checker/o'reilleys and get the pulley puller for gm's. for the install tool use a bout 8in of 16m x 2.0 all thred and some washers and a couple of washers trust us it will make the install a breeze also do yourself a favor and get the ARP pulley bolt a a replacement bolt.
