Thrust bearing trashed...what are my options?
Old Aug 14, 2010 | 02:46 PM
Polynikes's Avatar
Default Thrust bearing trashed...what are my options?
Title says it all. I bought a 2001 LS1 with 80K miles, tore it down and the thrust bearing is trashed. So the crank is garbage. What are my options here? Can I just pick up a crank, have the machine shop look over everything and throw it all back together with new bearings etc...? Or are there other issues that must be considered? I really don't even know what the culprit was that caused this in the first place as I bought the engine and trans as a pullout.
Old Aug 14, 2010 | 02:50 PM
01ssreda4's Avatar
Have you measured endplay? Just curious as I had one open up to .040 and the crank was rubbing the block. Stock should be .004 to .008. Yes you could buy a crank only, drop off everything you have to a machine shop and let them assemble it with new bearings. Some places can weld the thrust surface on the crank and regrind it back to spec, but the ones I talked to said they weren't confident on the weld holding. Here's my faulure:
https://ls1tech.com/forums/racers-lo...ew-engine.html
The biggest problem is to ensure it doesn't happen again. Is this an M6 or A4?
Old Aug 14, 2010 | 03:35 PM
Polynikes's Avatar
I didn't measure, but there was a ton of slack in it. Enough that I could move the crank back and forth a fair bit so it would make a 'clunking' noise where it was hitting.
Its an A4, and that's what I'm worried about the most. I don't want to put this thing all back together only to have it happen again. What would cause this? I'm assuming something trans or converter related, pushing on the crank? I guess it would be wise to have the trans checked out too.
Old Aug 14, 2010 | 05:47 PM
01ssreda4's Avatar
Converter ballooning could push forward on the crank. Could have too high of line pressures. Thrust damage seems to be a grey subject. Its hard to say exactly what causes the damage. But yes, I heard that a trans, converter, engine accs, and even engine electrical could cause thrust damage. Do some searching around and you will see what I mean.
Old Aug 14, 2010 | 07:59 PM
01ssreda4's Avatar
well it would be the rearward thrust if something was pushing forward.
Old Apr 1, 2015 | 02:57 PM
laurentj23's Avatar
Sorry to bring it up. Im having issues with my engine as well.
What are the symptoms showing a bad thrust bearings?
My crank sensor keep going off even when it is brand new
Old Apr 1, 2015 | 04:03 PM
01ssreda4's Avatar
Crank loosing signal is one, I had an oil pressure dip on hard throttle which is what tipped me off.
