Question on getting heads checked
Old Aug 16, 2010 | 12:51 PM
Adam86's Avatar
Default Question on getting heads checked
Hey guys, I need a new pair of heads for my TA and am probably going to pick up a used set off of a '98 for $80.
Searching through some threads it sounds like I'll want to bring them to a machine shop to get the heads checked for straightness and check the valves. I called up RPM Engineering here in Faribault and they quoted me $115 to clean both heads, completely check them over, and make sure the valves are seating properly. Does this sound like a good price to you guys or should I keep shopping around? They're the only machine shop in town but I'm close to the Twin Cities so my options are somewhat open. Thanks!
Old Aug 17, 2010 | 06:21 AM
BaddBird's Avatar
The last set I had sent out cost $72 to have cleaned and checked.
Old Aug 17, 2010 | 07:04 AM
BlackScreaminMachine's Avatar
Internet Mechanic
IF you can go look for a used set of LS6's off a Z06 or GTO, you may not be paying much more and they are a better head, heck even 2001+ LS1 head would be better.
As far as price, that sounds right.
Old Aug 17, 2010 | 10:42 AM
Adam86's Avatar
Thanks guys. I am looking to get away from this as cheap as possible and don't want to buy new valve covers. Also, I am going FI soon so I don't want to bump up my compression at all. If I could find some 6.0 heads for dirt cheap, that would probably be the only thing I would swap out for over '98 heads.
Old Aug 17, 2010 | 11:29 AM
Internet Mechanic
I'd start searching, untill you pony up for the 5K FI set up having a bump is not going to hurt you.
Old Aug 17, 2010 | 05:26 PM
KCS's Avatar
KCS
Moderator
Aren't you limited to those graphite head gaskets with the old 853 heads? I don't know if you would want to have to use those with boost.
Old Aug 17, 2010 | 11:17 PM
Adam86's Avatar
Turbo is already bought and is in the living room. It's funny **** isn't it? Nothing goes wrong with this damn car until I shell out the cash for that damn turbo!$&*#*@)@!!!!!!
Old Aug 17, 2010 | 11:18 PM
Adam86's Avatar
How do you mean? I haven't heard that before. But honestly the most I plan on pushing out for quite a while until I get better heads is going to be 7-8psi.
Old Aug 18, 2010 | 11:07 PM
KCS's Avatar
KCS
Moderator
Had to dig way back, but I found it...
Originally Posted by 427
Ryan, some early cylinder heads had 2 small cast in notches along the spark plug side on the gasket surface. If your heads have these you cannot use the newer mls gaskets or the engine will leak water externally along the block edge. If you have these notches you will need the graphite gasket to seal the water system.
Kurt
This happened to a good friend of mine just recently. He mistakenly used the MLS gaskets and water leaked everywhere. I think they were the 853's, but Kurt Urban (427) has mentioned above how to tell.
Old Aug 21, 2010 | 03:21 PM
hlaalu's Avatar
I was just quoted $80 to mill my heads, then another $40 to have them disassembled and checked out. Hopefully that all includes cleaning too.
