My LS1 is not a LS1
Old Aug 19, 2010 | 06:23 PM
ss mike's Avatar
Default My LS1 is not a LS1
OK, I bought a used LS1 out of a wrecked T/A. I could see it had 317 heads. I started tearing it down today and discovered the block is a 6.0L iron block. I know some people like these because you can bore them and get more CI. I was going to get a set of 243 heads and a LS6 intake for my LS1, don't know now. Any suggestions from all you gearheads out there. I am putting it in a classic truck-street rod, not a track car.
Old Aug 19, 2010 | 06:26 PM
projectX's Avatar
Don't see why you still couldn't do that.
Old Aug 19, 2010 | 07:01 PM
JAX04's Avatar
u my friend found a diamond in the rough
Old Aug 19, 2010 | 07:10 PM
ss mike's Avatar
Why do you call it a diamond in the rough, what would you do with it?
Old Aug 19, 2010 | 07:11 PM
JAX04's Avatar
lol, you have the motor most people kill find on a budget. Its the budget boost motor of the century and the block and crank are responsible for many 9 sec cars hell the lq4 with rod bolts and springs has gone over 700whp
Old Aug 19, 2010 | 07:12 PM
1nasty86's Avatar
Turd Gen Guy
well you really need to know if its a lq4 or lq9 are the pistons flat or inverted?? and yes the ls6 intake and 243 heads will fit fine on the 6.0
Old Aug 19, 2010 | 07:19 PM
ss mike's Avatar
The pistons are flat
Steve01SS's Avatar
The 243 heads flow about the same as the 317's... it would just increase your compression ratio with 243's. I would keep them and put in a mild cam and an ls6 intake... Run it as is.
Old Aug 19, 2010 | 07:21 PM
yarrie's Avatar
thats an LQ9
Old Aug 19, 2010 | 07:25 PM
1nasty86's Avatar
Turd Gen Guy
the 243 heads will bump the compression of a lq9 to about 10.75-11.0 which is fine. more compression more power. id use the 243 heads and the ls6 intake. and get a cam spec'd by somebody. a 230/234 would be a good driveable cam, imo.
Old Aug 19, 2010 | 07:45 PM
Zbinkley's Avatar
Diamond in the rough??? These motors are a dime a dozen.
Old Aug 19, 2010 | 07:48 PM
chasgiv3's Avatar
Definitely the LQ9 with 10:1 compression ratio. Requires 92 Octane and weighs 416lbs. Produces 347 HP in stock form. 6.0 liter displacement
The LS1
Displacement = 5.7 L. / 346 CID
Bore x Stroke = 99mm x 92mm / 3.90" x 3.62"
Compression Ratio = 10.1:1
Horsepower = 335 HP @ 5,200 RPM (out of Fbody)
Weight is 425 lbs
Looks to me that the only downside to the block would be cooling efficiency. I know when I swapped in my LQ4 I had to go with a high flow water pump otherwise when idling in 90 plus heat the car would want to overheat. The heatsoak would cause problems without it. I swear I thought the Iron block was 90lbs heavier but GM says no. Odd to me.
JAX04's Avatar
OK. Maybe i shouldve been more specific.
To the OP.
You went to the junk yard, or where ever to buy and LS1 from a wrecked car. what you got was a 6.0 motor. lol.
So you got more then what you bargained for.
is that better Zbinkley??
i was referring to the fact that he was after a 346ci motor with 241 heads and got a 364 ci motor with 317 heads.
so, with that said, IMO, he got more then what he was looking for.
i would be ecstatic to get one of those in place of an ls1
Old Aug 19, 2010 | 07:51 PM
1nasty86's Avatar
Turd Gen Guy
you are correct! the iron block weighs about 90lbs more. but id rather have the 6.0 over the ls1. personal preferance.
Old Aug 19, 2010 | 08:13 PM
SOMbitch's Avatar
The 4.0" bore gives you much better head options. On a budget get some L92 heads and a L76/L92 intake and you have a great bang for the buck. They are more finicky about the cam than a cathedral head but the right combo will beat a budget cathedral setup everytime.... The increased compression of the LQ9 is a big bonus too. You lucked out my friend.....
Old Aug 19, 2010 | 08:16 PM
flintwrench69's Avatar
So a 6.0 truck motor is worth more than an LS1? I would agree with your statement if it was maybe an LS2. I understand a lot use the iron 6.0 to make power with but from what I have read you can pick one up for a lot cheaper than an LS1. Depends on what he paid for it I guess.
Old Aug 19, 2010 | 08:19 PM
JAX04's Avatar
i was thinking the same thing when i typed it. LS1s go for less then the LQ motors in my part. Atleast at my local LKQ.
i could pick up ls1 for around 800, but LQ4/9 go for around 1200 here.
Old Aug 19, 2010 | 08:29 PM
1nasty86's Avatar
Turd Gen Guy
EVERYTHINGS HIGH IN ALABAMA!
Old Aug 19, 2010 | 08:54 PM
09camaro383's Avatar
I can get in Arizona a almost complete lq9 except for the intake in 600 it comes from ignition coils to oil pan i guess i should go and pick it up and the ls1 sell for 1200
Old Aug 19, 2010 | 09:00 PM
djfury05's Avatar
x2 on everything he said.. L92 heads have more potential than cathedral and flow 320 cfm right out of the box. Not to mention they are about $800 for a pair assembled ready to go... and the L76 intake comes with the throttle body ready to go for under $500.. can you say 450-475 rwhp without the blink of an eye?
