help with cam
Old Aug 18, 2010 | 04:33 PM
1998_trans_am_ls1's Avatar
Default help with cam
my car was wrecked and need to replace the front end so nows the time for a cam swap. im 17 and employed but still dont have unlimited money. i was thinking gm hot cam but every one says you should go bigger. i dont have a stall converter yet so i cant go that big whats some other options i can go with besides the gm hot cam without spending a ton, or should i get the hot cam? ill be doing the swap my self me and my dad. ill prob be getting some 243's so it will breath better.
Old Aug 18, 2010 | 05:00 PM
garygnu's Avatar
a TSP 224r cam kit at a 114 lsa.$125 for a frost tune.
Old Aug 18, 2010 | 05:40 PM
ive thought about the 224r what would be the power gains over the hot cam? because the hot cam is alot cheaper if i can find one used
Old Aug 18, 2010 | 07:29 PM
ds98formula's Avatar
More power and peice of mind of a new cam are worth themextra 100-150 you will pay
Old Aug 18, 2010 | 10:15 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Lets not go down the Hotcam route again. Unless you can find it for 40$ with springs its worth it to spend your money for either a proven newer lobe profile or a custom cam.
Old Aug 18, 2010 | 10:20 PM
Brandon35thSS's Avatar
get a stall first and save up for a cam. the stall will put a much bigger smile on your face than a cammed car without a stall.
Old Aug 18, 2010 | 10:29 PM
no1izspeshl's Avatar
This guy speaks the truth! A friend of mine had only bolt ons. Long tubes/lid. Had a 4400 Circle D stall and would run low 13s like 13.0x-13.2x consistently. Even had a best of 12.8x.This is all in 5000+ elevation with 6500-8000 DA lol.
Old Aug 18, 2010 | 11:58 PM
true ive thought about that but my front end is off so im doing my cam now regardless. getting a stall soon after. i love the sound of the hot cam's idle will the 224r sound that good at idle ive never heard one in person.
Old Aug 19, 2010 | 12:24 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Its all in the valve overlap to determine what the lope sounds like.
Hotcam has a -1.5° valve overlap.
Depending on the 224's LSA it is probably a 0° or a -2° or -4°.
Old Aug 19, 2010 | 03:45 PM
Bo's 98 TA's Avatar
I used to have a tr224 114lsa and u could tell there was a cam there, and it makes great power u will like it.
Old Aug 19, 2010 | 11:59 PM
then looks like it will prob be the tr224 inless i find a hotcam real cheap. is it safe to drive with that cam without a stall for a few months untill i get a stall?
Old Aug 20, 2010 | 06:51 AM
garygnu's Avatar
you will be safe to drive,you should get a tune right away.which lsa are you choosing?
Old Aug 20, 2010 | 07:55 AM
Very safe to drive it as long as it is tuned prolly not as fun as it will be when you get a stall but it will not hurt anything
Old Aug 21, 2010 | 06:25 PM
prob 114 lsa i wanna here it. and okay good to here ill prob get a tune right away or very soon after from frost
Old Aug 22, 2010 | 05:29 PM
02sslayer's Avatar
Its not really necesary to have the front of the car off to swap a cam. U just have to take the radiator out and move the AC condensor over a little. All that takes no time at all
