Coolant light coming on usually when hot, radiator and overflow always seem full
My wife`s `98 Trans Am is having an issue where the coolant level light is always coming on, and some times it doesnt come on until the car gets up to temperature. She doesn`t have any over heating problems. It always stays below 210, even in really hot weather. I just went to check the coolant levels after about an hour and a half of sitting, and the radiator is filled to the top, and there is plenty of coolant in the overflow tank. Anyone know what could be causing this? The light doesn`t seem to come as often when the engine is cool.
Thanks
Thanks
Restricted User
possible air in the cylinder head... try running the car with the cap off the overflow tank and squeeze the rad hoses multiple times to attempt to "burp" the system... also try it with the rad cap off too... good luck... o yea the fluid gets hot also hha so watchout
I have this same issue in my 98 WS6. I flushed the coolant and thought I burped/bled it enough, so there shouldn't be any air in there. I also pissed away $50 on a new coolant level sensor only to have the damn light come back on everytime the car gets up to operating temps. This is very annoying. If the coolant isnt low, and the sensor is new, what else is there to check?
I checked the connections at the plug and they seem fine. This light is driving me mad.
