decking surface
Old Aug 19, 2010 | 10:03 PM
jrocstar's Avatar
Default decking surface
Ok I just ran the math on my setup. The heads I have are stockers with large combustion chambers leaving me with a total of about 7.9:1 compression. I was considering milling the heads .020 to get my compression back up to 8.8 or 8.9. I am running a full forged engine planning about 20psi. I am concerned the additional loss of deck surface of the heads will make them lift easily. Should I just go aftermarket? What are the thoughts?
Old Aug 20, 2010 | 09:21 PM
jrocstar's Avatar
anyone?
Old Aug 21, 2010 | 04:49 PM
jrocstar's Avatar
Ok let's do this. What kinda boost is everyone running with stock cylinder heads? I see people are saying 8psi on stock heads they lift but I am running cometics and arp studs. That with a lower compression ratio I figure I may be ok.
Old Aug 21, 2010 | 04:54 PM
yelo04goat's Avatar
i know a guy running 20lbs on 317 heads i goin to try 18-20 on my slightly milled 243 heads
Old Aug 22, 2010 | 10:45 AM
jrocstar's Avatar
ok sweet thank you. anyone else? mods can we move this to forced induction sub-forum?
