valve seals?
Old Aug 20, 2010 | 08:10 PM
00 black ss's Avatar
Default valve seals?
what is the proper way to instal valve seals?
Old Aug 21, 2010 | 12:24 PM
can anybody help me out??
Old Aug 21, 2010 | 12:52 PM
09camaro383's Avatar
they sell this tool http://www.jegs.com/i/JEGS/555/80596/10002/-1 or you can use a deep socket same size as the seal OD!! just press down on the seal and just tap it a little if you don't think is all the way down if you tap it too much or hard it will damage the seal
Old Aug 21, 2010 | 06:01 PM
soundengineer's Avatar
dont forget that there are different seals for the intake and exhaust valves...
exhaust valve seals are made to handle more heat.
Old Aug 21, 2010 | 06:18 PM
chon79's Avatar
There is a Kent Moore tool you can get. I used a 10mm deep socket and tapped with a hammer and it was chewing up the little spring. Switched to a 12mm and it worked perfect! Just listen when you tap, you can hear when it bottoms out. on the valve.
Old Aug 21, 2010 | 07:24 PM
vettenuts's Avatar
Per the manual, after installation there is a measurement you take to ensure it is fully seated.
Are these one piece seat/seal or just seals?
Old Aug 21, 2010 | 10:35 PM
these are the seals http://www.summitracing.com/parts/CCA-511-16/
Old Aug 25, 2010 | 08:12 PM
are the seals suppose to sit flush on the seat? i have prc seats?
