Which Melling Oil Pump Do I Need?
Im just wondering is the the High Performance one just over kill or would it be a better choice for the extra $20.00?
And im running a LS6 if that matters.
Pump specifications:
over 30% higher volume capacity pump than stock LS1/LS6/LS2 pump
displacement of 1.26 in3/rev (compared to the 0.95 in3/rev on the stock LS1/LS6/LS2 type pump)
8/9 gear set with thicker gear than LS1/LS6/LS2 stock pump
Includes:
high volume oil pump
high pressure oil spring (installed in the pump)
standard pressure oil spring
replacement O-rings (for car and truck applications)
Includes:
And I do have a larger oil pan. This is for my 02 Z06 my car holds 6.5 quarts of oil compared to a F-Body that hold 5.5. So even with larger oil pan should I still get the stock replacement one?
