Pushrod Length and Valve lash
Lunati Cam (mild street/strip) with stock lifters, Patriot heads, and Jesel 1.85 shaft mounted rocker arms (overkill I know, but I couldn't pass up the deal off ebay). I am measuring pushrod length, on both sides of the engine, intake and exhaust, and I am getting 7.250" for length.
1. Does this seem too short?
2. Or have others had to use this length before?
Valve lash - this is my first h/c/i etc build. With Jesels, the valve lash is set using the adjuster cup on the rocker arm.
1. With hydraulic lifters on an LS1, what is the recommended valve preload or lash?
I would assume no lash as its a hydraulic setup, but again, newbs first mild LS1 build.
Thanks for the help!!
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I probably should have just used the stock rockers and saved these for a much wilder LSX build...next time
