Truck/Car Starter Issue
Now I'm under the impression these starters are interchangeable, but I want to confirm that.
Here's the problem, install the starter, bolt it up properly, when you go to start it, you here the gear pop out and that's it. Then if you turn the motor by hand as soon as you move it the smallest amount you hear the gear pop back in, like it's immediately binding up.
The motor turns freely like it should, we've tried it with the plugs out, with every possible power source imaginable hooked up directly to the starter, every possible method of grounding, so I think it's been ruled out to not be an electrical issue at all but a mechanical one.
Any ideas?
Maybe you could take the fbody starters into a parts store and ask to see the Envoy starter then compare?
Of course we're using the correct length bolts, I just wanted to know if the alignment of the snout and things was the same.
The only other thing I could think of is if one flywheel is bigger (more teeth) than the other
I shimmed the hell out of it in every direction possible last night to no avail.
I'm going to pick up the correct part number today from Autozone and see if that makes any difference.
Thanks
-Slamd-
I guess the blocks are different so things don't line up the same?
I'll report back tomorrow after I get the LQ starter and see what happens!
