Mystery bolt; where doesit go?
Old Aug 25, 2010 | 06:44 PM
after dark's Avatar
Default Mystery bolt; where doesit go?
I am putting on a set of 243's and installing a EPS cam. I am putting everything back together and i find this bolt...it is a 13mm and i can't figure out where it goes.
Attached Thumbnails Mystery bolt; where doesit go?-cimg3151.jpg   Mystery bolt; where doesit go?-cimg3153.jpg   Mystery bolt; where doesit go?-cimg3154.jpg
Old Aug 25, 2010 | 06:54 PM
crazygn's Avatar
tranny to engine bolt maybe
Old Aug 25, 2010 | 07:02 PM
vaticano's Avatar
Perhaps the power steering pump
Old Aug 25, 2010 | 07:23 PM
KingOfCold's Avatar
That is now whats known as a "trashcan item"
Old Aug 25, 2010 | 07:30 PM
after dark's Avatar
Yeah i thought about that so I took the pump off to confirm; I had all the correct bolts on the pump and bracket...it is only about1/4" wide
Oh yeah it from a 2000 T/A
Old Aug 25, 2010 | 07:47 PM
Firechikn's Avatar
compressor bracket to block?
Old Aug 25, 2010 | 07:50 PM
after dark's Avatar
No. I looked at that also, those are 15mm
Old Aug 25, 2010 | 07:53 PM
jsteele90's Avatar
waterpump?
Old Aug 25, 2010 | 07:59 PM
99Bluz28's Avatar
Originally Posted by jsteele90
waterpump?
No, it's to short to be for the water-pump.
Maybe a mount bolt for the belt tensioner, or a idler pulley bolt, or possibly a TB mount bolt.
Old Aug 25, 2010 | 08:05 PM
after dark's Avatar
thanks for the quick replies! Please keep the ideas coming
Old Aug 25, 2010 | 08:10 PM
1baaadz28's Avatar
its the bolt that goes in the back of the ALTERNATOR
Old Aug 25, 2010 | 08:17 PM
after dark's Avatar
Please explain...I don't remember that. I know there are the three long bolts that go in the front to hold the bracket and alternator.
Old Aug 25, 2010 | 08:22 PM
89 formula350's Avatar
yep was beat to it
the rear bracket to alt
Old Aug 25, 2010 | 08:28 PM
SOMbitch's Avatar
HAha! I swapped a gen I over in my 78 truck in 94 and had 1 bolt leftover I could never figure out.... Sold the truck in 99 and it was still running like a Timex in 07 last time I saw it...
Old Aug 25, 2010 | 08:39 PM
1baaadz28's Avatar
I cant be 100% sure but i believe its the bolt that hold the ground stra into the back of the alternator i dont have a way to post a pic but i have all my bolts that ive taken out of the motor(building a 383) in ziplock baggies labled with what they go to and thats the only 13 mm with a tapered thread i can find
Old Aug 25, 2010 | 09:09 PM
after dark's Avatar
That could be it, i cant check it out till tomorrow...Yeah I should have done the baggie thing, but I didnt and look what happens. You know now that I think about it was under my alternator (which I put in a box) when i went to reinstall it.
Old Aug 26, 2010 | 11:26 AM
Gatsby's Avatar
I like these games, we should have someone pull a random fastener every week to see if we can figure it out.
Let us know if that was it.
Old Aug 26, 2010 | 11:33 AM
04gtoBMXracer's Avatar
+1 for trashcan bolt. Its an "extra".
Old Aug 26, 2010 | 11:43 AM
black98ws6ta's Avatar
It is 100% without a doubt the bolt that holds the bracket to the rear of the alternator as said above. Then it has another bolt that goes to the raised portion on the side of the block. There is no ground strap here factory. Bracket looks like this:
Old Aug 26, 2010 | 11:50 AM
after dark's Avatar
I sure will... I will look tonight when I get home.
