1.75 rockers
Old Aug 26, 2010 | 09:17 PM
texas twister's Avatar
Default 1.75 rockers
im running a tsp 224r with 243 non milled heads,,will there be valve clearnce problem with 1.75 rockers,,,has any body run this set up?
Old Aug 28, 2010 | 09:06 PM
bumpp
Old Aug 28, 2010 | 10:33 PM
camz28arro's Avatar
Well that would put that cam at about .598 lift. found this using search feature:
"I run a 232/234 .595 .598 112 LSA cam with 62cc 243's safely"
Since his heads are milled about 16-18 thousandths to get to 62cc, I would think you would be fine but still should check your PTV before startup since it is getting close.
