arp rod bolt ? on ls1
Old Aug 31, 2010 | 12:24 AM
s10pro's Avatar
Default arp rod bolt ? on ls1
some one is telling me arp rod bolts are junk on ls1 ,and they let go and if you use them only have a mech shop do them. what the hell is the difrence if they being mech shop tq them or i do . info please
Old Aug 31, 2010 | 12:29 AM
The_Rizzle's Avatar
Set them in by torquing them a couple times. The distorting bore arguement I'm pretty sure is based off the older sbc rods. Forged PM rods are VERY stiff, and are not easy to distort.
I'd have no second thoughts using them in any of my builds using stock rods. Just set them in a couple times to make sure you're getting as close to the optimum stretch possible w/o using a stretch gauge.
Old Aug 31, 2010 | 12:53 AM
KCS's Avatar
KCS
Moderator
Ever measured a set after installing ARP rod bolts?
Old Aug 31, 2010 | 01:18 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I wouldnt hesitate to install them on any LS motor.
Old Aug 31, 2010 | 09:18 AM
blsnelling's Avatar
I have purchased ARP2000 rod bolts for my 6.0 build. I will be having the machine shop bolt the caps on and check for size.
Old Aug 31, 2010 | 10:29 AM
03supercobra's Avatar
Any time you change to different rod bolts, you should have the rods checked for size.
Old Aug 31, 2010 | 10:35 AM
blsnelling's Avatar
I don't expect to find an issue, but I'm checking just to make sure. It's easy enough to do while the engine is disassembled.
Old Aug 31, 2010 | 02:15 PM
incbed's Avatar
I went back looking for the thread were I read this and found that the ARP 2000 rod bolts have been known to change the big end by .002. That they do resize the rods when they use them ,,,,but this person has used them in his personal car without resizing the rods and has turned 7200rpm and has over 10k miles on the rod bolts with no problem so far.
Old Aug 31, 2010 | 02:37 PM
The_Rizzle's Avatar
You're right, I haven't. So I can't say with 100% certainty that they won't distort. However, forged PM is a very stiff material. Add to that the fracture split cap, which makes it harder to distort the bore, with the downside being resizing is a lot of work. A quick hone would be all you can do economically.
As for incbed^^^ are you sure its not .0003" ?? .003" is 3 thousands, which is more than the rod bearing clearance...
Old Aug 31, 2010 | 02:47 PM
incbed's Avatar
I want to change my original responce,,I went back looking for the thread were I read this and found that the ARP 2000 rod bolts have been known to change the big end by .002. That they do resize the rods when they use them ,,,,but this person has used them in his personal car without resizing the rods and has turned 7200rpm and has over 10k miles on the rod bolts with no problem so far.
Old Aug 31, 2010 | 04:07 PM
KCS's Avatar
KCS
Moderator
Resizing the rods is not a lot of work. A quick hone really is all you need to do.
I've actually measured a few and they typically change enough to need to be resized, but it's not so much the diameter at 12 and 6 o'clock, but the out of round in the housing bore that gets bad.
Old Aug 31, 2010 | 08:01 PM
s10pro's Avatar
thank you for all the info
Old Sep 1, 2010 | 04:47 PM
greyghost4x4's Avatar
Banging some gears
i've been told that you cant resize the LS series stock rods due to them being a "broken" style rod.. is this true?
Old Sep 1, 2010 | 05:02 PM
KCS's Avatar
KCS
Moderator
Not true. You simply hone the rod big end .002" larger to correct the geometry, similar to as if you were honing a cylinder for an oversized piston. You then open up a catalog for your favorite bearing manufacturer, and find the appropriate bearing part number for a stock rod honed .002" larger. I'm pretty sure for a Clevite bearing, you look for part number CH-1776-P.
Old Sep 3, 2010 | 12:10 AM
EricD's Avatar
Do any of you believe on what Katech claims about there bolts being installed and not needing to resize at all , i ask because i want to install new rod bolts with motor in truck but i am stuck , i believe the katechs are very close to the stock weight so that is good , has anyone here used the katech bolts , i have trouble understanding what sets there bolts apart, thanks Eric
Old Sep 3, 2010 | 12:59 AM
ShortChevy's Avatar
Katechs are pricey but worth it. You think a company with a reputation like Katech would lie about a claim like that? They are the same weight and length as stock so as not to put the rod out of round and change the clamp load. I have them, no i didn't measure after install. Yes I take the car to 6400+ EVERYDAY.
Old Sep 3, 2010 | 05:13 AM
GraphicNature's Avatar
i take my stock rod bolts to 6800 to 7000 rpm everytime the motors get started
Old Sep 3, 2010 | 07:44 AM
KCS's Avatar
KCS
Moderator
...so as not to put the rod out of round and change the clamp load.
If there isn't an increase in clamping load, then what is the point?
I'm not an expert, but from what I understand about fasteners, the clamping load (what keeps the rod together) needs to be greater than the intertial load (what tries to tear the rod apart). If you are trying to turn an engine to a higher RPM, which is increasing that inertial load, wouldn't you want a rod bolt with more clamping load to handle that increase in RPM?
Maybe there actually is an increase in clamp load, but it's less than that of the cheaper ARP's so as not to deform the big end.
Old Sep 3, 2010 | 02:01 PM
ShortChevy's Avatar
Some people do that and never have a problem what so ever. Others not soo lucky. Not saying they are required. I'm just not a gambler. $200 is cheapers then $3000 worth of longblock.
Old Sep 3, 2010 | 02:04 PM
ShortChevy's Avatar
That is my understanding on the Katech's. More clamp load would then deform the big end slightly. My guess would just be the material in which the Katech's are made from being that much stronger as to resist the intertial force trying to pull the big end apart.
