egr question( houston tx)
Old Aug 31, 2010 | 03:53 PM
99-L3thalZ28's Avatar
Default egr question( houston tx)
I have read a lot on deleting the EGR. If i delete it from my car can it still pass the emission test here in texas?
Old Aug 31, 2010 | 08:07 PM
heartless_T/A99's Avatar
i didnt know texas did emission test's. I've had my EGR deleted for maybe 6 months now and everything is fine and dandy.
Old Sep 1, 2010 | 11:21 AM
I'm in houston and to get the inspection sticker they hook up to your computer read it for codes and many other things i think.
Old Sep 1, 2010 | 11:34 AM
grgboca's Avatar
I think you can if you get the codes tuned out. Then you would just have to pass the visual
Old Sep 1, 2010 | 12:25 PM
ok thanks
Old Sep 1, 2010 | 02:05 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
You might get more feedback from locals in the Texas section (near the bottom of the main forum page)!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Sep 17, 2010 | 06:27 AM
fastazzls1's Avatar
No it will not pass i work at Munday Chevrolet on 45 as driveability tech and it is an emissions control device that is monitored by PCM to reduce production of NoX which is created at 2500 degrees egr valve allows inert exhaust gas to displace the presence of oxygen to reduce heat also Nox is generated due to heat and pressure. the egr it does not rob power and is useful i have an 1999 ss that produces 500hp and still retains egr valve driven to work and track
Old Sep 17, 2010 | 08:07 AM
ultradriver10000's Avatar
I live in Houston and if you pull off the AIR PUMP and EGR you can still pass inspection you just need your computer tuned. I can tune these out if you're interested shoot me a PM. I can also help you remove the ERG and AIR as they are just extra weight and garbage.
My C5 doesn't have Air, egr or cats and I pass with no problems.
Fastazzls1, you have a nice sounding car want to run sometime I don't live far from Munday. What tracks do you like hitting up?
Old Sep 17, 2010 | 08:30 AM
fastazzls1's Avatar
Baytown HMP dnt matter what is done to your car and yes you are right about tuning it out do you use HP tuners to tune your cars and whats all done to your vette
Old Sep 17, 2010 | 08:35 AM
fastazzls1's Avatar
I was also telling him if he didnt have a tuner that wouldnt pass didnt mention that though lol its under mode 6 for emissions and is a monitor when getting expected AND WHAT DO YOU CHARGE FOR A TUNE
Old Sep 17, 2010 | 08:51 AM
SSHAWK's Avatar
It will pass just don't take the egr pump out of the car just leave it hooked up.
Your pump is under your bottom right headlight.
NO CODE Problem solved unitl you can get your tune and have it removed.
Old Sep 17, 2010 | 08:58 AM
fastazzls1's Avatar
that is the AIR PUMP for catalsyt light off the egr uses a pressure differential to operate
Old Sep 17, 2010 | 09:56 AM
slt200mph's Avatar
Take the EGR off and throw it away it is dead weight..you can have it and all other emissions stuff tuned out of the PCM...I've been running without all that crap for over 200,000 miles now ..
