MS3 cam in an LQ9?
Hey guys new to the forum. I'm currently swapping a LQ9 into my 95 z28 and the guy I'm getting the engine from told me he will throw in a ms3 cam for free if I want it. Will this cam work in the lq9 or will I have ptv clearence issues? I thought I had read before that the pistons had to be flycut but I wasn't sure.
Any help appreciated!
LS1Tech Premium Sponsor
It will fit without having to flycut the pistons! You would definitely benefit from more compression (for example a stock or ported LS6 head would be a budget friendly way to go)! Make sure he installs a good spring kit and a set of hardened pushrods while he's there. You'll need all the bolt-ons to allow the engine to breath properly, and plenty of gear/stall to get you into that tall power band!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
yes agreed and dont overlook not putting those gears in i have a similar size cam def needs the gears . but the 243s are great with that set up and a good dual spring kit anything that can handle over .600 lift
