Mystery 6.0 block
We get core blocks in from a supplier. They can be from anything, I've even received LY6 6.0 iron blocks, long as they're iron LS block he drops them off to me.
Any ideas? i'm thinking its a marine app. block? Forklift application?
The block measures correctly for 6.0, mystery block has fine thread main bolts.
Water jackets are slightly different. It uses long head bolts.
block on left is mystery block,
The Mystery block also had one of these for the timing chain
http://www.gm.com/vehicles/innovatio...L96_Marine.pdf
See Larger Image GM Performance Parts 6.0L LS2 Aluminum Engine Blocks Engine Block - Aluminum - 4-Bolt Mains - 4.000 in. Diameter Bore - 2-Piece Rear Main Seal - Chevy - LS2 - 6.0L
Brand: GM Performance Parts, Mfr Part#: 12568950
he has no mention of what the mystery block is made of. just that he has received iron blocks from his supplier.
One person suggested this block could be from Isuzu and/or Kodiak trucks.
http://www.isuzucv.com/engines/gas_index.html
Kurt
