are rods backwards?
The rods are suppose to have the angled edge away from the other rod on the same journal and the smooth straight edge against one another. Well they are opposite of that.
So my question is, are the numbers stamped on the bottom of the pistons require them to be in the labeled cylinders or can I swap the two pistons and correct the backward rod problem?
You can swap the rods to the correst position, but make sure the piston is facing the correct way. The dot should be facing the front of the motor.
It's possible that someone has been inside the engine before you and mixed it up.
I guess I should have mention these are Scat rods on SRS forged pistons.
But I managed to flip the rods around on the pistons, Those spring retainers on the floating wrist pins are not easy to get out of the piston.
