Valve Seals Swap (checklist)
I initially didnt swap the valve seals because it was not smoking too bad, but after I did springs the smoking is getting to be excessive.
I dont want to mess around with the top dead center for the valves, because it makes it trickier to get the retainers back on since the valve drops a little.
I want to order a fitting for the spark plug hole and use a compressor to help.
Where can I find this online? any links would help.
Also, is there anything I need to know when doing valve seals on the 00 stock 853 heads?
Engine currently has around 103k miles.
Thanks!
Well I'm off to order parts....let me know if you guys think of something. Thanks!
No it doesn't. TDC is the most efficient way to do Valve Springs/Seals IMO. The valves do not drop far enough to cause a problem. Just compress the spring all the way down. You'd rather spend 10-15 minutes on EACH cylinder wrestling with an air hose and trying to line it up in the hole properly? Especially #7 and #8. Good luck. I'll take my 3 seconds to spin the motor 90* and have 2 cylinders @ TDC. Good luck.
