why is my car missing 30rwhp?(compression #'s inside)
Old Jan 25, 2004 | 10:20 PM
parker770's Avatar
Default why is my car missing 30rwhp?(compression #'s inside)
first let me explain the situation. the car had been feeling slow lately, so I took it and got it dynoed and it only made 348rwhp, 318tq.
setup:
'99 Z28 6spd
Pacesetter LT's, whisper lid, home ported TB, F1 cam w/ comp 918's, Lanes 3" true duals, full LS1 Edit tuning by Chris Robinson
finally got around to doing a compression test today, and was just wondering what all you knowledgable people thought about the numbers. this was on a cold motor, with the throttle held wide open:
1-140
3-145
5-140
7-140
2-140
4-125
6-140
8-140
number 4 is obviously the one that is low, does this look like a headgasket problem? or maybe a bent valve? what do you guys think?
Old Jan 25, 2004 | 10:57 PM
mgreen's Avatar
I'm not sure if your cam has such different characteristics or your engine is missing some compression. . .but stock is like 160. With my hotcam it's 195-205.
Mike
Old Jan 26, 2004 | 07:41 AM
v8maro's Avatar
How long have ur springs been on there?
Old Jan 26, 2004 | 08:09 AM
jimmyblue's Avatar
Moderator
Number 4 is 10% out, I would repeat the cranking
compression test just to be sure it wasn't a fluke.
These are pretty high pressures for a cam of any
overlap; 10.5:1 cranking compression is pretty good.
You might try a leakdown test to diagnose the
leakage path (if any); compressed air in the plug hole,
listen for where it comes out. Crankcase=rings,
intake/exhaust = valve or head gasket. Springs by
inspection up top (for any gross tension drop /
breakage).
Bent pushrod hurts opening, not closing, not a
likely culprit here.
Old Jan 26, 2004 | 01:59 PM
parker770's Avatar
the valve springs only have about 4k on them(blue stripe 918's)
Old Jan 27, 2004 | 04:48 PM
WILWAXU's Avatar
moving to Internal Engine section.
Old Jan 27, 2004 | 06:22 PM
cueball's Avatar
breakage).
on a leakdown test, how much psi should be used on the ls1 engine?
thanks
