suggestions 408 engine gurus 2slow? build sheet inside
Get a used FAST 92/92 to open up the top end, the engine needs to suck some air too. Less than $1k used.
I would leave the heads right now and see where that would put you first before getting some AFR230s or something and spending a lot.
I don't think that car made 525 truthfully, my car at sea-level with a cam bigger than that through a 6 speed made 508hp/478tq. Can't say it didn't because it could be a happy dyno. But that 408 should run faster than that, and that topend seems way mis-matched for that car. Truthfully I am in the same boat and need heads like its my job, but you should have nothing smaller than 225cc heads if you want a performer along with atleast a ported FAST92 or FAST102 combo.
I'm ashamed for posting my times but made only 2 runs I made with my 408, the fastest was my 2nd run:
60'-2.4
1/8-9.0@90
1/4-12.1@122
although the 32mph between the 1/8-1/4 shows powerThat was with a massively bogging 60' and hitting the rev limiter in 2nd and 3rd. Your mph compared to my crappy run should be a tad higher or match it I imagine if your making 525whp. Something is definitely up somewhere in your powerband fella.
Although it's not as fast as you wanted, congrats though fella. Its still a respectable car
I'm watching this thread as my motor comes thursday, I'm going with a little TSP V2 cam on a 404 LQ9, 3400 Circle-D Stall, but I have a great set of TEA LS6 Stage 2 heads, FAST 92 / NW 92... could care less about the dyno numbers, I want to see 11.3 in the quarter !
Are you sure it's even a 408?
Either the car is loaded to hilt and weighs 4,000lbs with a huge stereo system, extremely bad tune, or the motor is shot.
A 408 even if limited with AFR205/Fast 78/Medium cam should trap more then 115mph. I'd run a compression test.
Something doesn't make sense. Your 60' is decent... Trap speed seems way low to me.
Put that girl on a diet!
