Timing Chain
Old Sep 5, 2010 | 09:10 PM
snolan's Avatar
Default Timing Chain
Can anyone help with a spec of timing chain stretch i would just replace it but no one has one ...
Seems to move about 1/2 to 3/4 when pushed out or in
Old Sep 6, 2010 | 06:53 AM
EricD's Avatar
i believe sdpc has a very good one and it is not expensive , the stretch your talking about seems right with one side tightened up , if you get that on both sides at the same time it is to much , i would get a complete set because if the chain is worn to the point of replacing it the gears will be worn to the point that the new chain alone will never fit right, sdpc has a complete set for 90 bucks , Eric
