benifits of ls2 timing chain???
Old Sep 7, 2010 | 01:24 AM
rooster18's Avatar
Default benifits of ls2 timing chain???
can someone please fill me in, i am oblivious on this subject. should i consider doing one when i do my cam swap to MS3 (in like 2 weeks)??? if so, what all do i need to get to do it and where can i get it?? thanks yall
Old Sep 7, 2010 | 04:26 AM
*02WS6TURK*'s Avatar
You should IMO always swap in a new chain during a cam swap. The LS2 chain is the chain a GM dealer would now give you because our chains are no longer available. Either The LS2 or the C5-R chain would do you good. If you want some added strength and don't mind spending a few extra bucks then go with the C5-R.
Old Sep 7, 2010 | 12:40 PM
Lambert695's Avatar
LS2 is stronger. Not saying the LS1 chains break all the time but with a cam in there it is always good to have extra support
Old Sep 7, 2010 | 12:50 PM
01ssreda4's Avatar
LS2 chain is clearly stronger and thicker. LS2 sprocket has a 1x reluctor (solid raised section) on the cam gear thats not needed for LS1s since our cam sensor is located on the rear of the cam. It however, does not interfere with anything so its all good I would replace the chain/sprockets together. Yank, a sponsor on here, has the LS2 sets for right at $70 shipped. The thread is in the classified section.
Old Sep 7, 2010 | 03:10 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Sorry for the huge pic, LS1 chain is on top and the LS2 on the bottom
Old Sep 7, 2010 | 03:11 PM
01ssreda4's Avatar
Holy resize....
Old Sep 7, 2010 | 03:35 PM
My monitor just sent a message reading "PC LOAD LETTER" and then blew up.
Old Sep 8, 2010 | 12:46 PM
BennyB's Avatar
the ls2 chain definetly looks beefier
Old Sep 8, 2010 | 05:05 PM
Z28/2002's Avatar
I copied and pasted from another thread and didn't feel like resizing it
Old Sep 8, 2010 | 05:29 PM
Jeff Smith's Avatar
wow. big difference ls1 and ls2...
