Time for new valve springs
Likewise, I see thread after thread of guys commenting about their springs only lasting x number of miles, or they bent x number of pushrods, etc. Coincidence?
I'm very fortunate that I measured my installed height, because I was measuring a height that would put me just a few thousands out of coil bind. I suspect that a LOT of guys are in that range where they're only a few thousands away from bind. At that very narrow height, unless all of the coils compress at a 100% perfectly equal rate (they don't), you're going to result in some coils hitting their neighbors, which over time is going to weaken the spring.
You guys that have had 50k miles out of your springs are proof that when you're not into bind, these springs can last a long time, but those of you who are getting 10-15k miles are probably so close to bind that some of the coils have collided enough times to weaken the spring.
Putting these things in without measuring their height is dumb.
FYI A valve spring height micrometer can be purchased for about $50 from Summit Racing.
