Anything wrong with Patriot Heads
Old Sep 8, 2010 | 01:50 AM
Egg1456's Avatar
Default Anything wrong with Patriot Heads
Been thinking about putting some ported LS6 heads on the bird soon and i am considering Patriot heads their flow data seems to out flow other heads. Ive seen some guys on here talking crap on them but is there actually anything wrong with them. Also considering trick flow heads. Thanks.
Old Sep 8, 2010 | 02:04 AM
fatmat80's Avatar
i went with PRC but its a personal decision like being an autobot or a desepticon..lol but if money or price is not a deciding factor then go with TFS..I dont think there is anything wrong with patriot but i do think there are better products out there..
Old Sep 8, 2010 | 02:35 AM
Arc00TA's Avatar
Trick flow is top of the line stuff, not really even comparable to the patriots. IMO, many of the budget ported LS6 heads don't offer very substantial gains to make the price worth it over stock 243's. I'f I'm going to spend $1500 on ported LS6's I'll save a little more and get some AFR or TFS heads.
I had a very similar setup to you, 224 cam with stock 243's and put down 425/405 on a conservative tune.
Old Sep 8, 2010 | 04:00 AM
TXZ28LS1's Avatar
nothing wrong with patriots. if you look at the dyno section, you will see the last few people who have ran patriots made good power. but i woul choose TSP/PRC heads or TEA heads over patriots if i was on a budget.
Old Sep 8, 2010 | 07:52 AM
06tx4.8's Avatar
12 Second Truck Club
i would go PRC. Patriot is good, but they produce heads for all types of motors(gen 1 sbc, bbc, 4.6 mod motors, etc.), whereas PRC specializes in the LS platform
Old Sep 8, 2010 | 10:08 AM
caseypryan's Avatar
I have heard they drop valves often..haven't seen it personally but have friends that have...
Old Sep 8, 2010 | 10:29 AM
Damian's Avatar
LSX Mechanic
Advertised "Flow data" is the absolute last thing you should use when considering a cylinder head purchase. Companies play the #'s game with flow charts just like anything else. It's all marketing. Flow #'s can also be manipulated using a pipe to bloat the exhaust cfm.
In some cases it's the companies that dont post flow data that produce the best results.
Old Sep 8, 2010 | 12:43 PM
Egg1456's Avatar
if im going to spend over 2k on some new heads would you guys go with prc, trick flow, or afr? Im really trying to make as big power as i can with just cam and if im gonna spend that much and the best is only a few hundred bucks more might as well get the best.
 Michael S. Palmer
Old Sep 8, 2010 | 12:58 PM
King Nothing's Avatar
don't forget to check out west coast racing cylinder head, they have some bad *** heads also
Old Sep 8, 2010 | 01:22 PM
twitchtwice's Avatar
out of all those i would say afr
Old Sep 8, 2010 | 01:47 PM
NVR_SPDS's Avatar
Id go AFR. Their heads seem to make killer power even with smaller cams.
Old Sep 8, 2010 | 02:14 PM
Dirty Vegas's Avatar
You're really wasting your time with ported stock casting heads. $ vs. HP, not really worth it. Trick Flow and AFR are both really good heads, leaning slightly more towards AFR because Tony Mamo is pretty active in the LSx community and really seems to know his stuff. However, there are a couple vendors here that have had great success with the Trick Flows. If you're having a shop do the work, see what they have been doing and what produced the best results. If you're doing it on your own, talk to Tony Mamo.
Old Sep 8, 2010 | 02:17 PM
MastMotorsports's Avatar
Dont forget about us!
We offer a complete line of Cathedral Port heads! Let me know if I can help.
Thanks,
Old Sep 8, 2010 | 07:40 PM
hcb1700's Avatar
Definitely AFR's.
Egg1456's Avatar
anybody know if Tony Mamo also ports heads? i was wanting to have him port my intake and tb. Im sure it would flow like no other if he did all 3 with some 1 7/8 headers.
Old Sep 8, 2010 | 07:53 PM
I dont know if he does anything to the AFR heads, but i know he will port match the intake to the heads. Why dont you contact him and ask him? He seems like an easy guy to talk to and also seems very helpful.
Old Sep 8, 2010 | 08:03 PM
garygnu's Avatar
Tony ports AFR heads.
Old Sep 8, 2010 | 08:06 PM
vettenuts's Avatar
Yes, he will. On the old 205's it wasn't so much porting as un-shrouding the intake valve through some hand work in the chamber. I had that done on my heads. Now the 205's are replaced with the new 210's and the intake side flows similar to my hand worked head, which may be the working model of the new 210 head. AFR just released some head updates and they should be even better then before. I would definitely contact Tony to get the latest scoop.
Old Sep 8, 2010 | 08:58 PM
Egg1456's Avatar
yea im gonna get ahold of him when im closer to doing the swap. just getting basic idea of what route i wanna go.
Old Sep 8, 2010 | 09:02 PM
t-1's Avatar
t-1
1004 sae whp here, on patriot ls6 stg 3's... but its turbo
