HELP! what gasketts, head bolt or stud with stage 2 heads?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
hi,
i'm having stage 2 5.3 patriot heads installed. what kind of head gaskett should i go with?
also, what head bolt or stud do i need,
the car only has a TR224 cam, LT, and the PP 5.3 heads, should i do bolts or studs (ARP?)
thanks,
thanks,
Originally Posted by Classic
The GM head gaskets are good. Also, I would highly recommend head studs - it makes things 100 times easier/faster if you ever have to swap heads again.
i don't really think i will ever change the heads in the future, so is using GM head bolts ok? or should i upgrade to ARP? the price of the ARP is a little high, so is it worth it, is it going to be stronger?
thanks,
thanks,
