Is a 2002 C5 intake a Ls6?
Old Sep 9, 2010 | 02:30 PM
Micah41091's Avatar
Default Is a 2002 C5 intake a Ls6?
I found a intake off a 2002 C5 Corvette it has no egr tubing like a Ls6 intake. Wondering if it is also a Ls6 intake on C5's or if thats just the Z06 Vettes
Old Sep 9, 2010 | 02:35 PM
Jon@Texas-Speed's Avatar
Yes it should be an LS6.
Old Sep 9, 2010 | 02:41 PM
Micah41091's Avatar
I've also been told that the '01 and '02 F-bodys came with the ls6 intake. I've been getting alot of mixed answers.
Old Sep 9, 2010 | 02:43 PM
BlackScreaminMachine's Avatar
Internet Mechanic
F-body and Corvette LS1 based Car got that LS6 type intake from the Factory. There is a part # difference between the 2 but is essentially the same intake. There are links on how to identify the difference beyond the part # and heir apparent hole for the EGR in which the underside has a specific pattern of ridges.
I had a LS6 on my 2002 T/A, Sold it to for funds to buy a FAST 90/90, but then 2 years later I moved back to a LS6 and I still checked the part # to verify. It turned out to be a Corvette LS6.
Old Sep 9, 2010 | 06:15 PM
01'SSLSX's Avatar
to the OP, yes it is
and if anyone would know, it would be these guys!^^^^^
Old Sep 9, 2010 | 10:30 PM
twitchtwice's Avatar
all 2001+ ls1 engines had the ls6 intake
Old Sep 9, 2010 | 11:20 PM
Micah41091's Avatar
Thank yall very much. Just wanted to make sure.
Old Sep 10, 2010 | 03:25 PM
Mike454SS's Avatar
I believe that part number difference has to do with wether or not the intake has the press fit brass ferrules necessary to bolt on a cable throttle bracket in an F-Body and 2004 GTO as Vette's were drive by wire, and I HAVE seen some manifolds without those ferrules.
Old Mar 6, 2011 | 06:28 PM
Mr MasterCraft's Avatar
This post is from 6 months ago... but I've been wondering the same thing since I just picked up my '02 C5. So two things...
It works
And as always, thanks to TSP and the always reliable information from tech members
