Clearence
Old Jan 26, 2004 | 05:29 PM
GrapeApe's Avatar
Default Clearence
I'm thinking of doing a custom grind --i'm thinking on like a 226/234/575/588@112+2 with that spec would i have a p/v clearence problem? --i'm useing comp magnum lifters and heads were milled like 5-10k when freshend up
Old Jan 26, 2004 | 06:37 PM
Grimes's Avatar
It's hard to tell with uncommon combos or custom cams, like you are planning to do. I would guess that you would not have a problem. However, since the heads were milled, I would clay the pistons to make sure.
Old Jan 26, 2004 | 07:30 PM
SSInnovations's Avatar
I'd say stick with whats proven to work, and there are so many cam choices from so many manufacturers I'd see no need to get a custom grind. Just my 2 cents.
